56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Masking Regions
Tue, Nov 13, 2007 at 7:09:54 PM | Masking Regions
SteveB
3.5 Stars: 5 Votes
When creating a tag, you can add a "masking region".  this seems to mask an area within the tag, but only in display, not in print.  You can create a solid fill area with no line weight (in the tag), this produces what I would call a masking region.  What's the purpose of "masking regions"?
Wed, Nov 14, 2007 at 3:55:48 AM | Masking Regions
IDN101
2.5 Stars: 3 Votes
Masking Regions are basically there to "mask out" something in a view that you don't want to see.
Commonly used as a way of detailing complicated wall junctions in plan, for example.
They can be 2D or 3D.
Regards,
Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Wed, Nov 14, 2007 at 7:16:57 AM | Masking Regions
SteveB
3.5 Stars: 5 Votes
Why don't they mask when I print?  They do mask in the display.
Wed, Nov 14, 2007 at 10:07:16 AM | Masking Regions
kiknchikn
I have found it’s much easier to simply create a filled region with invisible lines, then give the filled region a solid white fill. That is the guarantee way to work.
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Exporting to Autocad with Masking Regions
Thu, Apr 25, 2013 at 10:33:27 AM
11
Revit 2010 Masking Regions
Mon, Nov 30, 2009 at 4:42:34 PM
Masking Regions not "masking"
Mon, Dec 14, 2009 at 11:21:22 PM
masking regions
Mon, May 11, 2009 at 4:31:49 PM
Page generation time: 12.9370
