72 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Avatech Earth Connector. Anyone know where to get instructions?
Mon, Nov 12, 2007 at 4:53:14 PM | Avatech Earth Connector. Anyone know where to get instructions?
Hogmodo
Hogmodo Avatar
3.5 Stars: 6 Votes
Autodesk has this new download for connecting Revit to Google Earth.  Included is the Avatech Earth Connector that places your building model on the Google Earth 3D map.  The only problem I am having is trying to get the model shifted to the exact spot on the Google Earth photo.  Can't find any instructions on Avatech's website.
Wed, Feb 24, 2010 at 7:30:29 AM | Avatech Earth Connector. Anyone know where to get instructions?
mattmas
I'm sure that this is much too late to help you - but in case others stumble upon this:
There is a tutorial in the directory where the Avatech Utilities for Revit are installed. There are a couple of basic strategies for matching up the origin of the model with a location in Google Earth - most require two iterations:
You will generally want to start by making a guess at it - putting a placemark into Google Earth at the origin, and then saving that placemark as a KML file.
When running Earth Connector, you can set the location of the model origin based on an imported KML placemark.
That should get things close - but there are two approaches to make things closer:
 1. You can shift the model origin to a new location once you have seen it in place to make a correction.
2. Inside Earth Connector, you can choose "Place Marker" which will place a family at the origin. You may then move that marker family to a new location (such as the corner of the building or property line - something that will be easy to cross-reference by the location of your Google Earth reference placemark).
Good Luck,
Matt
Rotating a model imported into Google Earth
Wed, Oct 24, 2007 at 8:54:54 AM
Google Earth extension
Mon, Jun 9, 2008 at 5:39:14 AM
Family Editor - Duct Connector
Mon, Jun 16, 2014 at 1:52:02 PM
Duct Connector Not Visible??
Thu, Feb 17, 2011 at 11:41:01 AM
Below grade earth pattern missing
Thu, Nov 10, 2016 at 2:58:12 AM
Page generation time: 0.1983
