Forums >> Revit Building >> Technical Support >> Newbie's problems help appreciated
3 Posts No Rating |
Hi have had Revit for a while but am now just being trained in its use. Have been to one training session out of 3 so have a long way to go. Second was posponed because the trainer was ill. Problem is I have committed the Use of the programme for a clients project and am doing very well so far. I am at the roof stage with almost everything else done. When I put the roof on which is a traditional dual pitched roof I am getting stuck. Can any one give me an idiots guide to putting on my roof. I have the gables drawn in. Assistance appreciated Simon
3 Posts No Rating |
Sorry should have said 2008 version TA
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
Can you tell us which bit exactly you are having a problem with. In a nutshell: -Make sure you're on an appropriate Level to start with -Select "Roof" -Choose a method for defining ie "By Footprint", "Using Sketch Lines", etc, etc -Tell Revit about the roof you want (ie sketch it's plan, set slopes, set roof type, etc -Let Revit make the Roof Regards, Ian
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
3 Posts No Rating |
Ian Thnaks for the reply. Initially it was drawing a dual pitched roof but have resolved that from one of the other threads. The problem that I am still having is where one roof intersects with another forming the valley. Having drawn this I end up with the two roofs passing through on another. Simon
Ignore my previous reply! I've just knocked up a quick tutorial on my site, which should answer your question. http://www.revitzone.com/index.php?option=com_content&task=view&id=721&Itemid=49 Regards, Ian
![OktoberFire Avatar](user_avatar/44610.jpg)
64 Posts No Rating |
" great site and tutorial, im new to revit and it seems so far the hardest part has been drawing roofs with soffits etc i still havent mastered it yet though
Soffits are no problem: Just enter the soffit width you want into the "Overhang" box (on the Options Bar, when you're in "Roof Mode" . Regards, Ian
the main problem im having it getting the roof to align with the soffit and when i to on the brickwork, the roof sits within it. also drawing soffits on gable ends, and how to do hip roofs sooo much to learn
A good way to get upto speed with Revit is to read.... http://students2.autodesk.com/ama/orig/RAC-2008-CurriculaLectureNotes_Final.pdf Covers all the fundamentals. If you got anything specific on roofs you need help with- give me a shout and I'll try and squeeze in some extra step-by-step tutorials. Regards,Ian
Newbie needs help |
Mon, Dec 28, 2009 at 8:45:27 AM
Revit newbie - Few questions |
Sat, Feb 9, 2013 at 10:50:07 PM
Having problems with my Project Browser, a newbie question |
Mon, May 2, 2011 at 12:38:33 AM
Problems plotting |
Mon, Nov 9, 2009 at 3:38:20 PM
Newbie - Can't view in 3d |
Tue, Apr 1, 2014 at 9:24:52 AM
Members: | 2017271 | Objects: | 22947 | Forum Posts: | 152212 | Job Listings: | 3 |
