52 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> Duplication of details on different sheets
1 Posts No Rating |
Is it possible to have a 'sim' detail on a different sheet from the orignal reference, while maintaining the automatic update of the references?
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
When you are making the new callout, check the "reference other view" and then it will let you pick the view that you want it to reference to. HTH
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
If you have Revit Arch 08:- Right click on the view in question, Duplicate View > Duplicate as Dependent
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
![bauhaus1919 Avatar](user_avatar/16150.jpg)
![3.5 Stars: 9 Votes](/images/stars_3.5.gif) |
Philty, if you are asking whether it is "possible to have 'sim' detail" MARKER that reference the same detail, then JHanby is correct. If you want to have a detail actually appear on multiple sheets (in the case of Supplementals for instance), then I have not found a way. I generally Duplicate with Detailing and rename it with something on the end ("SUPP" in the case of supplementals). IDN101, I have never been able to Duplicate as Dependent any Drafting View or Detail View. Is this a setting somewhere...maybe a Revit quirk I'm not aware of? I would love to have this ability.
Finding Unreferenced Details Already on Sheets |
Sun, May 13, 2018 at 5:10:42 AM
Revit 2014 Export Sheets or Save to new file |
Thu, Jan 28, 2016 at 11:21:21 AM
Typical Details |
Thu, Aug 28, 2014 at 7:54:38 AM
What is the best Method for moving CAD details into Revit Details? |
Fri, Oct 9, 2009 at 9:24:47 AM
Linking Multiple AutoCad Details |
Mon, Jun 9, 2008 at 3:51:32 PM
Members: | 2026645 | Objects: | 22994 | Forum Posts: | 152211 | Job Listings: | 3 |
