96 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> New to revit - how would i get a drawing like this from ACAD
Fri, Nov 9, 2007 at 6:09:06 AM | New to revit - how would i get a drawing like this from ACAD
OktoberFire
OktoberFire Avatar
the attached image is a typical planning drawing i would do in autocad, what im wondering is.
when in revit, how would i get the brick coursing other the garage door, and the brick coursing following the roof line?
Fri, Nov 9, 2007 at 9:01:19 AM | New to revit - how would i get a drawing like this from ACAD
sdbrown
5 Stars: 3 Votes
You will use a sweep with a model surf. pattern with the spacing. There is a check box to rotate with element.
Exported file to ACAD has problems with custom PATTERNS [made in acad]
Mon, Jun 23, 2008 at 3:21:33 PM
dimensions missing after exporting to ACAD
Mon, Jan 5, 2009 at 3:18:53 PM
linking from acad
Sun, May 15, 2005 at 12:43:43 PM
ACAD file moves in revit
Wed, Jan 15, 2014 at 7:30:31 AM
ACAD export filled region
Tue, Aug 4, 2009 at 7:09:17 AM
Page generation time: 1.6733
