64 Users Online (62 Members):
Forums >> Revit Building >> Technical Support >> section view
4 Posts No Rating |
in my building sections the walls are coming up soild gray. stem wall and footing is solid gray as well. there is no hatch pattern for cmu and footing. its is hard to see my detail components through the gray background in sections. any thing that i can do to get the visibility right. elevations work fine but not the sections. i attached an example
You can't see the details because you are in "corse" mode, in left botton, just in the right units click and choose "fine".
4 Posts No Rating |
Thanks typhoon, tried it but it still shows up the same there was actually no change. i fiddled with those settings but still cant get it right. any other suggestions?
64 Posts No Rating |
change the fill style for the walls in the wall properties?
4 Posts No Rating |
tried that too with no avail.
what scale are you viewing the section at?
Have you checked your view settings for phase and phase filter? Items created earlier than the current phase by default show up grey.
Section box in Section?? |
Sat, Dec 10, 2011 at 10:23:01 PM
13
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
Section Title View deleted can not recover |
Tue, Jun 9, 2015 at 7:48:40 AM
Section view depth |
Tue, Jul 15, 2014 at 8:29:07 AM
Section markers disappear in plan when cropping the section view. |
Tue, Nov 27, 2007 at 3:33:58 PM
Members: | 2042232 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
