41 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Cavity closer - only closes on brickwork
Wed, Nov 7, 2007 at 11:49:38 AM | Cavity closer - only closes on brickwork
OktoberFire
OktoberFire Avatar
i have been editing my external doors to suit my needs, and i cant seem to get the cavity closer to close on the blockwork, it only seems to work on the brickwork.
any ideas?
i have set cavity closer to interior and it made no difference Sad
Wed, Nov 7, 2007 at 12:44:35 PM | Cavity closer - only closes on brickwork
ArchWestCY
4.5 Stars: 7 Votes
Could you please clairify.  I think that you are saying that when the door cuts you wall only the brick is wrapping.  Are you trying to get some CMU to wrap as well?  If this is the case the answer is in the Wall Properties.  It is hard to say based on the info youhave given.  Maybe you could post a picture of the problem.
Hope I can help
ArchWestCY
Fri, Nov 9, 2007 at 4:38:00 AM | Cavity closer - only closes on brickwork
OktoberFire
OktoberFire Avatar
hi thanks for the reply, the problem is that the external doors are set for opening inwards, if open them outwards the cavity closer is shifted into the blockwork and the brickwork returns.
Joining different Cavity walls
Mon, Jan 5, 2015 at 12:26:44 PM
Door/ Window Editing (help)
Fri, Oct 24, 2008 at 7:28:45 AM
OPENING REVEALS
Mon, Sep 27, 2004 at 3:22:13 AM
Cavity Wall - Cavity Not Filled
Mon, Jun 16, 2008 at 5:42:39 AM
Revit Closes every time it loads
Fri, Nov 30, 2012 at 7:30:03 AM
Page generation time: 0.1855
