67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> I made a 2 toilet stall family...problems with insertion
Wed, Nov 7, 2007 at 11:20:24 AM | I made a 2 toilet stall family...problems with insertion
jonblaze451
1 Stars: 1 Votes
I started a plumbing fixture family with a wall host default file.
The wall thickness is 6".
When I insert the component into a model with an 8" Nom. CMU wall, the component is inserted 1" into the wall.  I understand that the 6" wall in the family is the reason, but is there a way to insert the component without changing the wall size in the family to fit the wall size of the model?
Wed, Nov 7, 2007 at 3:00:48 PM | I made a 2 toilet stall family...problems with insertion
joonya
If you base the massing off of the wall faces reference plane as opposed to the wall centerline, then the component will base itself on the wall face in the model, regardless of wall thickness.
Tagging a family within a family
Mon, Oct 8, 2007 at 3:24:36 PM
Scheduling Components within Families
Mon, Dec 1, 2008 at 11:57:26 AM
Interior Elevation Adjustments - things just aren't showing up!?!
Wed, Jan 7, 2009 at 9:18:13 AM
masking region in toilet family - help me i'm a newbie!
Fri, Aug 10, 2007 at 2:50:03 PM
Revit 2012 - Edit Room Boundaries
Tue, Jul 5, 2016 at 9:38:19 AM
Page generation time: 1.8320
