88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> Revision table mystery
Tue, Nov 6, 2007 at 10:55:02 PM | Revision table mystery
Fluffyfatcat
3.5 Stars: 3 Votes
hi all
I'am using Revit 2008.
When I put my first revision cloud on the sheet and tag it -rev 1(by sheet) it placed the note in the revision table on my title block, so it all looks fine.
All next revision tags come with right revision number -rev2 & rev 3 etc ( each revision is properly recorded under settings-revisions with date etc), but  next revision cloud make  text dissapear from rev. table.
What do I do wrong?
regards
Fri, Dec 28, 2007 at 12:52:18 PM | Revision table mystery
scaledup
Did you ever find the answer to this? I'm having the same problem.
Tue, Jan 15, 2008 at 4:49:33 PM | Revision table mystery
Fluffyfatcat
3.5 Stars: 3 Votes
unfortunately no, did not have much time to look into it, cheers
Wed, Jan 16, 2008 at 11:21:02 AM | Revision table mystery
kesflower
3.5 Stars: 11 Votes
I too am looking for the answer to this question.  Anyone else know what to do?
Ruth Rau
Main Street Architecture, P.C.
Wed, Jan 23, 2008 at 6:48:08 AM | Revision table mystery
SteveB
3.5 Stars: 5 Votes
In pulldown "settings/revisions" you have to clik the "issued" check box before you go on to the new revision.  Did you do that?  Also there is a "By Project" or "by sheet" choice.  use by project if you want a new revision to have a new number regardless if the last revision is on this sheet or not.
Wed, Jan 23, 2008 at 5:27:45 PM | Revision table mystery
Fluffyfatcat
3.5 Stars: 3 Votes
hi Steve, thank for reply
I have tried it "by project" as well as "by sheet" and i checked the revision as issued - same result-the note dessapear from revision table field. Any other suggestions?
Wed, Jan 23, 2008 at 5:32:32 PM | Revision table mystery
SteveB
3.5 Stars: 5 Votes
Wed, Jan 23, 2008 at 5:47:20 PM | Revision table mystery
Fluffyfatcat
3.5 Stars: 3 Votes
yeah
i just tried it again,the minute i place another cloud (even before tagging it) the note of first revision vanishes
Wed, Jan 23, 2008 at 6:00:14 PM | Revision table mystery
SteveB
3.5 Stars: 5 Votes
again again again,
Wed, Jan 23, 2008 at 6:27:50 PM | Revision table mystery
Fluffyfatcat
3.5 Stars: 3 Votes
steve,
i went settings/revisions "by project" wrote my first rev., drew the cloud , tagged it -the rev. note appeared in the title block, then i went settings/revisions "by project" - clicked issued check box for the first rev. clicked apply, then wrote another revision, placed another cloud - and then my first rev. note disappeared from title block
I would also need revisions by sheet (not by project) for other project - that doesn't work either
sorry to be such a pest, but I need to resolve it
cheers Anna
Wed, Jan 23, 2008 at 11:25:59 PM | Revision table mystery
SteveB
3.5 Stars: 5 Votes
don't know.  You could try cliking on the title block, clik on edit family then you'll see the revision schedule, clik on it, right clik and "edit schedule", the right clik and choose veiw properties and see if it is sorted by something other than revision #.  Also try selecting or unselecting "itemize every instance" under "sorting/grouping? tab so it isn't summarizing some other way.  I leave it un checked
Thu, Jan 24, 2008 at 6:32:48 AM | Revision table mystery
SteveB
3.5 Stars: 5 Votes
2 last thoughts:  are you placing the clouds on the sheet or in the view (floor plan, sections etc?)
Are you sure you have all the same titlesheet files used on all the drawintgs?  we have similar looking title blocks that are actually different files and would have separate revision schedules.
Thu, Jan 24, 2008 at 9:33:08 PM | Revision table mystery
#13
Fluffyfatcat
3.5 Stars: 3 Votes
hey Steve
i can't thank u enough , schedule was not sorted by revision #..
it worked
great, cheers
Revision table
Fri, Sep 22, 2006 at 1:11:38 AM
Revision Tables
Fri, Jun 9, 2006 at 12:09:09 PM
i want the revision schedule only showing a specific revisions
Fri, Feb 10, 2012 at 11:54:42 AM
revision text color
Mon, Mar 25, 2019 at 1:17:51 PM
Revit revision table - alphabetical
Thu, Mar 13, 2014 at 3:35:50 AM
Page generation time: 0.8678
