59 Users Online (58 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Placing an imported family over a masked region.
Tue, Nov 6, 2007 at 11:40:32 AM | Placing an imported family over a masked region.
RevitMaster2007
I have a detail at a building expansion joint, i've placed a masked region where i want to place an expansion material, but i can't get the material to be placed on top of the region. There is no level control. Can anyone help? Thanks. RAC 2008
Tue, Nov 6, 2007 at 11:46:37 AM | Placing an imported family over a masked region.
LIZARD2806
3.5 Stars: 7 Votes
Select the masked region and click the button on the options bar that is all the way on the right (send backward) and that should allow the other stuff to be on top.
Tue, Nov 6, 2007 at 11:58:37 AM | Placing an imported family over a masked region.
RevitMaster2007
I did, like 20 times but it still won't let me place the family on top of the region. im stumped.
Tue, Nov 6, 2007 at 12:02:12 PM | Placing an imported family over a masked region.
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Have you tried making the masking region as part of the detail family. This should allow the region to mask any elements but still show your detailing.
Tue, Nov 6, 2007 at 12:27:41 PM | Placing an imported family over a masked region.
LIZARD2806
3.5 Stars: 7 Votes
What kind of family is it that you are trying to import?  You amy want to look at the section entitled, "Creating a Model Family with Masking Regions from 2D DWG Files" in the help file, expanding on what JAMESHGRIMES said.
Also, I know it is not what you asked, but did you consider using the Edit Cut Profile tool instead of a masking region?
Tue, Nov 6, 2007 at 1:02:50 PM | Placing an imported family over a masked region.
RevitMaster2007
James and Lizard,
I will try those techinques. Thanks for your help. I'll keep you posted.
changing Masked Region border lineweight
Mon, Feb 23, 2015 at 5:33:15 PM
DWG and Filled/Masked Region???
Thu, Jun 7, 2012 at 2:18:17 PM
Masking an imported link
Wed, Aug 24, 2011 at 7:06:36 AM
11
Logo / Filled region in Drawing Sheet
Fri, May 7, 2010 at 4:22:31 PM
Masking region in a family inside another family??
Tue, Jun 19, 2012 at 8:28:24 AM
Page generation time: 2.8492
