65 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Linked file coordinate problem
Mon, Nov 5, 2007 at 9:51:38 AM | Linked file coordinate problem
JacobsWyper
This morning I encountered the following message:  "Linked file [File name] cannot be saved because it has changes in more than just shared coordinates and therefore can invalidate local files owned by you."  The only option is "OK".I can still see the linked file; I can reload it from the location on our server successfully.  However, when I save to central I receive the same message as posted above.  I tried to remove the linked file and reload, and received the following message: "cannot get center of imported geometry in view to place import. imported file will not be centered on current view."
I expanded the view range to capture miles of model space and cannot see the import.  Under link manager it is not listed as being linked.  Teh physical file location and name on our servers match and appear unchanged.  To my knowledge nothgin was done to this file over the weekend.
Does anyone know what went wrong here?  Have you seen these messages before?  How can I specify an origin location in a REVIT file equivalent to a CAD 0,0,0?
Tue, Nov 6, 2007 at 3:58:30 PM | Linked file coordinate problem
JacobsWyper
I resolved this issue by removing the links and reinserting them into the file.  The origins on two seperate linked files appear to have lost their elevation relationship, which is why initially I could not see them; they were significantly below and off center.  I still do not know what caused the issue and welcome an explanation if anyone has any information on this issue. Thank you
Fri, Feb 27, 2009 at 5:45:31 PM | Linked file coordinate problem
Bimmer32
That is interesting. I wonder what can be done to fix it because it reoccurs.
Will the reset the Survey point affect consultant links?
Fri, Oct 22, 2010 at 10:26:14 AM
Why Coordinate System of the input dwg not retained ?
Mon, Jun 29, 2009 at 8:16:06 AM
Linked file visibilty problem
Thu, Nov 19, 2009 at 4:20:47 PM
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:17 PM
Linked Revit Model Sheets
Fri, Apr 5, 2013 at 12:04:29 PM
Page generation time: 1.5513
