75 Users Online (73 Members):
Forums >> Revit Building >> Technical Support >> View Title Extension Lines
![Bm3875 Avatar](user_avatar/11826.jpg)
![4 Stars: 7 Votes](/images/stars_4.gif) |
I was wondering if there was a way to modify/edit the extension lines of the view title families. Our office standard has an extra wide line with a thin line 1/16" above it. Is there a way to have two lines for the extension lines? Thanks,
Brandon Pike | Owner/BIM Specialist ![Photo Photo](http://lh6.googleusercontent.com/public/ok5WJ0t5CtLgka59pVXypK1UASDfFJ1TjNHSqryv1AtWcj8vbAVywBZRY3NmIFEaZgwjvJMqj14VRNxJXlF6FGHgKldjMNEgWkf4UBWuuw6INS8v3sHaAuI4j_u6)
cad.web.print website: http://www.thinkdesign-studios.com blog: http://www.bimtionary.blogspot.com/ |
You can not modify the automatic title with the adjustable line. Instead, you can make your own view title with fixed length lines. Might want one or two different sizes.
![3.5 Stars: 7 Votes](/images/stars_3.5.gif) |
WWHub is mostly correct, although I do not know of a way to have a double line, you CAN modify the standard extension line, but only the line weight and line pattern. Select the viewport title, then go into preferences, then click Edit/New. There you have the option of changing the line weight and line pattern. I quickly looked to see if you could create a double line line pattern, but did not see anything.
Hello... When the name of the view on the View sheets is a litter bit longer than usually, it takes two lines and the second one cut's the bottom’s line... How can i deal with it?... please!!
View Title Extension line |
Mon, Apr 23, 2007 at 6:38:22 PM
Deleting View Title Extension Line. |
Thu, Dec 27, 2007 at 10:06:05 AM
Automatic View Title Extension Length |
Sun, Dec 18, 2016 at 5:45:56 PM
View title extension line grips trouble |
Wed, Oct 9, 2013 at 2:04:27 PM
Is there a way to reverse the View Type Title? |
Mon, Aug 22, 2011 at 3:26:46 PM
Members: | 2016897 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
