67 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 2-pick family visibility problem
Mon, Nov 5, 2007 at 8:57:25 AM | 2-pick family visibility problem
bfell
I'm using 2-pick families instead of wall sweeps for base and crown mouldings so that I can have just the symbolic lines (at the desired line weights) that I need visible in interior elevations.
The sweeps that I'm using in the 2-pick family are set to be visible only in Left/Right.  When I place them in the model, everything looks good until I join the base/crown to the wall (so that it shows correctly when cut in section).  After joining to the wall, the 2-pick family sweep is displayed in Front/Back - in spite of the settings in the family.  Is this normal?
Visibility Problem - please help!!!
Fri, Jan 11, 2008 at 10:20:02 AM
Element Visibility Setting in Project
Mon, Jan 25, 2010 at 11:57:33 AM
Symbol in family visibility
Tue, Nov 3, 2009 at 9:00:07 AM
nested family visibility parameter
Sat, Jan 19, 2013 at 7:34:32 AM
Revit 2010 - Can't pick a line for plane to draw extrusions - HELP!!!
Thu, Aug 27, 2009 at 3:34:25 AM
Page generation time: 2.6108
