34 Users Online (33 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> General Discussion >> Revit Project Management >> Unable to add window to wall
Sun, Nov 4, 2007 at 6:08:04 AM | Unable to add window to wall
Lovebug
I have a 90mm brick wall and I recieve an error when trying to add a "Tpl Casement Top Hung Window"
 Get the following errors:
Can't make type "Tpl Casement - Top Hung Side".
None of the created elements are visible in Floor Plan: 00_Ground Floor View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings.
Sun, Nov 4, 2007 at 9:02:16 AM | Unable to add window to wall
IDN101
2.5 Stars: 3 Votes
I suspect your wall may be below the minimum thickness for that particular window family- you may have to make a copy of that window family and edit it to suit.
Regards,Ian
www.RevitZone.com
News / Articles / Tutorials / Forums / Beginners Guide to Revit
Sun, Nov 4, 2007 at 6:55:11 PM | Unable to add window to wall
falcon
I would agree that is most likely the issue.  Make sure that the window is not too large for the wall thickness.  That is the typical error.
Tue, Nov 6, 2007 at 9:20:06 AM | Unable to add window to wall
djs810
Why do you need to be able to put a window in your wall?
 Oh, sorry -  I was channelling AUGI moderators again...
Fleetwood window families unable to offset form exterior
Tue, Oct 18, 2016 at 10:24:43 AM
Wall and Window problems please help
Tue, Jul 8, 2008 at 10:21:31 AM
Adding Windows To Building: Help Needed Please
Wed, Jun 10, 2009 at 3:14:32 PM
existing wall keeps infilling when I add a window.
Sat, Nov 5, 2016 at 2:01:06 PM
how do you set a window back from the face of the wall of an exisitng window?
Tue, Mar 13, 2012 at 10:37:00 AM
Page generation time: 1.5842
