49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> weird question
2 Posts No Rating |
Hello, I am attempting to design a large motoryacht for my design class. I have designed the hull in a program called Delftship, and i exported it in a .dxf format. I want to design the interior around the hull in Revit, and i can upload the polymesh .dxf surface into Revit. However, I cannot use wall by face to create a "hull" on this surface. I am only a junior in high school and i don't know much about CAD formats. ANY information you can give me will be SO much appreciated. Thank you, Will
![2.5 Stars: 3 Votes](/images/stars_2.5.gif) |
Hi, Can you tell us more about what happens when you try to use Wall By Face? What messages do you get from Revit?
www.RevitZone.com News / Articles / Tutorials / Forums / Beginners Guide to Revit |
![3 Stars: 2 Votes](/images/stars_3.gif) |
USE MASSES. THEY HELP ALOT WITH WEIRD SHAPES, ALSO THEY ARE MORE FLEXIBLE...JUNIOR IN HIGH SCHOOL... WHICH ONE...SANTIAGO IM GUESSING.?
----------------------------------- DKO |
2 Posts No Rating |
hi, thank you guys for your reply. santiago? i have no idea what youre talking about... anyway when i have the mesh in 3d format, the wall by face will work on a few of the individual faces on the mesh, but only a few. Its confusing, i am uploading the .dxf format so you can see it for yourself. By the way, I am using Revit Architecture 2008.
Weird tag problem, question mark? |
Wed, May 9, 2012 at 6:52:38 AM
Weird Callout Problem |
Wed, Mar 19, 2008 at 2:51:20 PM
11
problem pads and subregions , weird depression on topography |
Sun, Mar 22, 2015 at 1:46:45 PM
Weird blocks of color appearing when plotting |
Fri, Apr 19, 2013 at 3:19:00 PM
Revit 2017 weird mapping in shape-modified floors |
Thu, May 11, 2017 at 11:56:49 PM
Members: | 2022391 | Objects: | 22974 | Forum Posts: | 152201 | Job Listings: | 3 |
