48 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Stacked Wall Sweep Returns (RAC 2008)
Fri, Nov 2, 2007 at 12:55:12 PM | Stacked Wall Sweep Returns (RAC 2008)
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
I origionally was using a couple different walls to achieve the look I wanted, but have since switched to a stacked wall.  My question is can you edit sweep returns on a stacked wall?  If I click on the wall, the dialog box that normally appears on a regular wall is no longer there. Any help would be greatly appreciated.
Dan
Fri, Nov 2, 2007 at 1:52:13 PM | Stacked Wall Sweep Returns (RAC 2008)
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
Your Stacked Wall is basically a wall defined by multiple Basic Walls that have the properties of the individual walls. If you edit the properties of the Basic Wall that was used in your Stacked Wall it should adjust in the Stacked Wall automatically. Here's a fast way to get to those properties from your Stacked Wall...in 3D or elevation view, mouse over the Stacked Wall so that it highlights, now hit tab to cycle through wall parts that make up that Stacked Wall. When the portion of the wall you want to edit lights up, click and hit properties. This is also the way that we set Stacked Walls to be load-bearing. You have to set it in the properties of each wall piece because it is not an option in the Stacked Wall properties (you can also touch a bar joist or something to it and it asks if you want to change it to load-bearing...but that's another thread). Hope that helps.
Mon, Nov 5, 2007 at 8:49:09 AM | Stacked Wall Sweep Returns (RAC 2008)
DTCesarz
DTCesarz Avatar
5 Stars: 4 Votes
Thanks.
stacked wall sweep cleanup
Fri, Feb 12, 2010 at 9:11:20 AM
wall sweep returns
Thu, Jun 1, 2006 at 11:53:23 AM
Sweep on Stacked Wall Error
Wed, May 30, 2018 at 2:24:44 PM
Breaking apart a Stacked Wall Issue
Wed, Mar 11, 2009 at 12:03:45 PM
Stacked Wall with Wall Sweep
Mon, Oct 5, 2009 at 4:34:42 PM
Page generation time: 1.1650
