88 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Window Swings Not Showing In Elevation
Fri, Nov 2, 2007 at 12:41:57 PM | Window Swings Not Showing In Elevation
jrotella
jrotella Avatar
3.5 Stars: 2 Votes
I have a building with a slanted wall and the window swings are not showing in elevation. I know that this is supposed to happen since the wall is technically not in true projection, but how can i override this? I have tried changing the lines in the family from symbolic to model and they still do not show. Can anyone help?Thanks,Jimmy
Fri, Nov 2, 2007 at 1:01:47 PM | Window Swings Not Showing In Elevation
You model lines in the window family will need to be on a plane that is in front of your window.  If you have some experience, you could make these a switchable item that is turned off in your 3d - otherwise the model lines will show up there too.
Window elements not showing in one elevation.
Mon, Jun 12, 2023 at 7:15:06 PM
Door swings not showing in plan view
Mon, May 5, 2008 at 7:27:38 PM
Door and Window Frames not showing in Elevation
Thu, Dec 17, 2015 at 4:34:06 AM
Exterior wall brick showing in window
Tue, Sep 7, 2010 at 12:59:13 PM
Phasing Issue - Proposed Elements showing solid white
Thu, Sep 3, 2015 at 7:36:04 AM
Page generation time: 1.6400
