69 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Schedules + Misspellings
Fri, Nov 2, 2007 at 9:33:39 AM | Revit Schedules + Misspellings
Jhui
We're adding room finishes to a job and putting them on a room finish schedule.  I noticed that I had completely misspelled "PAINTED".
 Is there a way to mass convert all PATINED into PAINTED instead of going to each individual cell to change it?
Fri, Nov 2, 2007 at 9:52:15 AM | Revit Schedules + Misspellings
You should be able to set up a temporary schedule with a filter that selects only these, turn off "show all instances" and then you will only have one line.  Correct that and your done.
Fri, Nov 2, 2007 at 10:03:39 AM | Revit Schedules + Misspellings
Jhui
That's very helpful.  Thanks.
Okay, so now, how about able to edit the finish so that the PATINED is now only PAINTED?
Fri, Nov 2, 2007 at 12:26:38 PM | Revit Schedules + Misspellings
? ? ?   Come on .... I don't understand what you are asking.  If this is an instance parameter, just correct the spelling!
Fri, Nov 2, 2007 at 1:16:38 PM | Revit Schedules + Misspellings
Jhui
For the mass changing, your suggestion worked right on the money.
The second was, on the schedule or even in the room properties, the pull down menu has both options.  I'd like to know if it is possible to delete an option
Fri, Nov 2, 2007 at 2:16:21 PM | Revit Schedules + Misspellings
If the misspelling still exists in the pull-down, it still exists somewhere in your project.  This pull down is only a reflection of all the choices that have already been entered.  Initially, there is none.  If you put in paint, there is only paint.  If you erase the paint (back arrow over the entry), the pull down will onece again be empty.
Be careful, if you have other options or phases where this misspelling may exist, it might remain in the pull-down.  (I don't know how REVIT treates this information across option and phases)
Fri, Nov 2, 2007 at 4:12:06 PM | Revit Schedules + Misspellings
ArchWestCY
4.5 Stars: 7 Votes
Just a side note.
Did you notice that Revit only Spell Checks notes typed in a drawing.  That is to say that Revit will not Spell Check your Schedules or Keynotes.  That's a major bummer if you ask me.  I just wanted to drop that hint so nobody is expecting Revit to find the spelling errors in their schedules.
ArchWestCY
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:34 AM
multiple schedules
Tue, May 1, 2012 at 1:04:43 PM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:13 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:02:00 PM
Large number of schedules
Mon, Jun 20, 2011 at 12:56:19 PM
Page generation time: 2.1825
