27 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Elevation tags hiding
17 Posts No Rating |
REVIT Architecture 2008 I have scattered chaos happening. My East elevation view symbol is showing up on the ground level and N.S.W. views are missing. And on my first level the N.S.W. view symbols are showing but the East is missing. How do I get these all on every sheet? If I copy and paste, it creates a new view. If I cut them and paste I can get them all on one sheet or the other but I still can't get them on all sheets. Aaaaaaaaaaaaah!
I would check the following: 1. If the East Elevation was cropped so that it stops before the first floor, it won;t show up in the first floor plan. Go to the East elevation and make sure that it displays the whole model. You can also go into View Properties and check the boxes for Crop View and Crop Region Visible to make sure they are set up properly. 2. If the elevations are set to "New Construction", then they will only be shown on plans that are "New Construction". If the East elevation view is set to existing, and the others are set to New Construction, you wont see it. 3. Make sure nothing is hidden. It could have been Hidden in the view. 4. Make sure the all the Disciplines are matching-if one was inadvertantly switched to Structural it won;t show up in an architectural view, for instance. Check that stuff and see if they come back. Cheers
It was the phase settings. Thank you! Thank you!
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Interior Elevation Tags |
Wed, Oct 9, 2013 at 2:23:36 PM
Hiding elevation tags |
Thu, Jan 27, 2011 at 12:39:44 AM
Hiding Detail Tags in other views [ 1 2 ] |
Thu, Jan 21, 2010 at 5:26:47 PM
21
Elevation Tags |
Tue, Oct 23, 2007 at 4:30:06 PM
Members: | 2056631 | Objects: | 23074 | Forum Posts: | 152327 | Job Listings: | 3 |
