184 Users Online (183 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Wall sweep not cutting right with a door
Thu, Nov 1, 2007 at 10:23:07 AM | Wall sweep not cutting right with a door
Surfrusty777
Hi, I have tile in a restroom going all the way up to the ceiling and when it gets to the door it is cut above the door.  Is there a way I can fix this?  Please see attached.  I'm using Revit 2008.
Thanks!
Surfrusty
Thu, Nov 1, 2007 at 3:04:13 PM | Wall sweep not cutting right with a door
LIZARD2806
3.5 Stars: 7 Votes
This is not an answer to your question, but I  was in the same situation, and what I did was to create a wall type of just the tile (new tile being applied to an existing wall), and then joined the two walls together.  By joining them, both will be cut by the door.  Hope that helps.Cheers.
**Using Revit Architecture 2009, 2011, and 2012**
Sat, Nov 3, 2007 at 12:43:11 AM | Wall sweep not cutting right with a door
Surfrusty777
Thanks!  That worked!
Door not cutting joined wall
Wed, Feb 14, 2018 at 12:54:55 PM
door opening cutting parallel wall
Mon, Sep 15, 2008 at 2:54:11 PM
gap in wall sweep without wall opening?
Thu, Apr 22, 2010 at 3:14:21 PM
how to make door frames cut wall sweep? [ 1 2 ]
Mon, Jun 9, 2008 at 8:11:28 AM
20
door not cutting wall
Mon, Apr 6, 2015 at 10:24:33 AM
Page generation time: 1.5362
