70 Users Online (69 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Room Names/Legend
Thu, Feb 17, 2005 at 5:11:00 PM | Room Names/Legend
jenniferg
Does anyone know if I can turn off room names while leaving on the numbers? Our office standard is to have as little text within the drawing as possible, so we use room legends for clarity. I know I can simply delete the room name, but then I won't have it in the legend, either. Thoughts? Thanks!
Thu, Feb 17, 2005 at 5:14:38 PM | RE: Room Names/Legend
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Create a new room tag that just incorporates the number. Load into the project, right click on one of the existing roof tags and choose, select all instances, then change them in the properties to the number only version. HTH.
Thu, Feb 17, 2005 at 5:16:24 PM | RE: Room Names/Legend
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I believe there is a new room tag that comes with Revit 7 which allows you to turn on and off the room name, number & area. I could be wrong. Nevertheless, if there isn't, you could create one by opening up your room tag, doing a save as and applying visibility parameters to your tag labels.
Hiroshi Jacobs
Thu, Feb 17, 2005 at 5:25:53 PM | RE: Room Names/Legend
jenniferg
Thanks so much for your help, guys. I ended up making a new annotation type with just the number. When I made a room legend, the names were still there somehow - lucky me! (I'm using 6.1, but this seems like yet another reason to get 7 -the curtain walls are a BEAR in 6.1!) Thanks again, Jen
Thu, Feb 17, 2005 at 5:27:49 PM | RE: Room Names/Legend
Steve_Stafford
5 Stars: 2 Votes
Quoting hjacobs - 2005-02-17 17:16:23
"I believe there is a new room tag that comes with Revit 7 which allows you to turn on and off the room name, number & area. I could be wrong. Nevertheless, if there isn't, you could create one by opening up your room tag, doing a save as and applying visibility parameters to your tag labels."
You're right Hiroshi, the stock tags with 7.0 use visibility parameters to allow you to turn on and off the values.
Post edited on 2005-02-17 17:28:35
Post edited on 2005-06-13 03:57:33
Thu, Feb 17, 2005 at 5:34:29 PM | RE: Room Names/Legend
jenniferg
For a curious new Revit user like myself, how would one apply visiblity parameters to the elements of an annotation family? (And is this possible in 6.1)
Thu, Feb 17, 2005 at 6:00:23 PM | RE: Room Names/Legend
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I don't think this is possible in Revit 6.1, I can't believe I missed it if it was... basically, at least in 7, all solids & labels have a yes/no parameter that controls visibility applied to them by default when created. The trick is you have to connect that individual solid or label visiblity parameter to a family parameter. This allows the family parameter to control the visibility of all items tied to it.
Hiroshi Jacobs
Change services's names in legend once created
Thu, Aug 4, 2011 at 8:35:25 AM
Room Tags not showing up in Floor plan.
Tue, Nov 9, 2010 at 1:06:51 PM
Color Scheme Legend Issues
Mon, Dec 1, 2014 at 6:26:39 AM
Abbreviating Room Tag Names vs. Schedule
Thu, Sep 1, 2011 at 2:05:15 PM
Room names not showing up when linking Revit files
Sat, Sep 25, 2010 at 1:35:31 PM
Page generation time: 0.4251
