77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> TOPO and Site Planning
Mon, Oct 29, 2007 at 8:49:00 PM | TOPO and Site Planning
aquietnyx
Revit Arch 2008
I'm trying to import an ACAD drawing, which i can import no problem, and use the elevation lines on there (2d drawing) and draw topo points from Revit on top of the existing lines from acad. But... some how i don't think i'm doint that right and its taking forever!
is there a way i can select the lines that i import and assign an elevation to them and then add a surface on top? or something along those lines....
any help asap would be GREATLY appreciated....
Email- aquietnyx@gmail.com
aim- x24silentKissesx
Mon, Oct 29, 2007 at 8:57:20 PM | TOPO and Site Planning
aquietnyx
here is the site
Mon, Oct 29, 2007 at 11:03:15 PM | TOPO and Site Planning
Erik
Sorry, I think not.  The topo feture in Revit is not that developed.  If your cad drawing is in 3D, you can generate points along the line when you import.
My issue, is that it take along time to make adjustments to the topographicel points, if you have a large site with many points.  Is there a way to turn off automatic drawing generationtion while working with the topo points and do a manual regenration? I guess the answer is 'No' :-). Can anyone make my day?
Mon, Oct 29, 2007 at 11:45:40 PM | TOPO and Site Planning
GregD
A very narrow subregion can form 3d representations of site boundaries.
my question:
Is there a way to form a cave or an undercut space in a topo surface such as a cliff face or steep hillside?
Tue, Oct 30, 2007 at 7:10:48 AM | TOPO and Site Planning
If the drawing you are importing and the lines are poly-lines, it's easier to assign those to an elevation in AutoCAD then import the drawing and assign the topography to the 3d linework.
Wall on Topo Site
Wed, May 28, 2008 at 5:00:38 AM
RAC 2009 - Topo Site Work
Fri, May 9, 2008 at 3:08:34 PM
level elevation doesn't match elev point in topo / site plan
Wed, Dec 18, 2013 at 4:05:00 AM
13
topo. surfeaces
Thu, Jan 10, 2008 at 9:59:44 AM
Could Revit allow curb or sidewalk sweeps to be attached to site topo edges?
Wed, Apr 26, 2006 at 4:42:17 PM
Page generation time: 6.3141
