43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Structural Silicon Glazing (SSG) Curtain Wall
Mon, Oct 29, 2007 at 11:52:41 AM | Structural Silicon Glazing (SSG) Curtain Wall
jjlangh
jjlangh Avatar
3 Stars: 2 Votes
I would like to use a SSG curtain wall system in my project but do not find it in any of the families that come with Revit. I have attached an image of the wall i would like to use. Has anyone been able to manipulate the curtain wall type properties to acheive this? The horizontal mullion is wider than the vertical (as shown). Any help would be greatly appreciated.
Mon, Oct 29, 2007 at 11:53:47 AM | Structural Silicon Glazing (SSG) Curtain Wall
jjlangh
jjlangh Avatar
3 Stars: 2 Votes
Oh, and I am using Revit 2008.
Mon, Oct 29, 2007 at 12:23:09 PM | Structural Silicon Glazing (SSG) Curtain Wall
Create your own profiles.... easy to do and a good learning lesson.
Mon, Oct 29, 2007 at 12:38:09 PM | Structural Silicon Glazing (SSG) Curtain Wall
jjlangh
jjlangh Avatar
3 Stars: 2 Votes
Should i start by duplicating an existing curtain wall?
Mon, Oct 29, 2007 at 11:57:09 PM | Structural Silicon Glazing (SSG) Curtain Wall
Erik
You are actually just changing the profile for the mullion.  I would create a simple glazing mullion profile with enough detail to suite the scale of your architectural drawings.
It is always a good idea to start with something existing.  It is easier to modify then to creat.
For the details as shown in your attachment, I would use detail components.  I believe there are details like you need,in the library (either with Revit or in RevitCity, line based not model based)
Thu, Nov 15, 2007 at 3:30:52 PM | Structural Silicon Glazing (SSG) Curtain Wall
ballen
Can u change the profile of the mullion in the model to show like abuted glass?? Or can this only be done w/ a detail component in a detail view??
Thu, Nov 15, 2007 at 5:56:34 PM | Structural Silicon Glazing (SSG) Curtain Wall
You can change the profile so it sits behind the glass as far as you want.
Fri, Nov 16, 2007 at 8:58:48 AM | Structural Silicon Glazing (SSG) Curtain Wall
ballen
OK.........so how is this done??
Fri, Nov 16, 2007 at 11:36:15 AM | Structural Silicon Glazing (SSG) Curtain Wall
Look through these sites along with thread searches here at REVITCITY.:
http://www.cadclips.com/
http://www.caddigest.com/subjects/revit/tutorials.htm
Learning what is already available will help you with a lot more than just this question.
Tue, Aug 10, 2010 at 2:40:51 PM | Structural Silicon Glazing (SSG) Curtain Wall
sockjock
I have a general question about curtain walls. When I'm actually ready to intall a curtain wall, where is the best place to find commerical glazing products? I've heard that Dow Corning has a few glazing products... are they any good? I recently saw that their silicone helped construct the world’s largest cable-net-supported glass wall in the New Poly Plaza. Looks really great.
 http://www.dowcorning.com/content/discover/new_poly_plaza.aspx
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
Cutain Wall. Horizontal Cap running over SSG Verticals?
Thu, Jul 29, 2010 at 8:35:42 AM
Raking curtain walls, adding tags to Shop Front glazing
Tue, Mar 7, 2006 at 9:35:58 PM
Glazing in curtain walls
Thu, Dec 10, 2015 at 7:38:15 AM
Curtain Wall scheduling
Mon, Feb 7, 2011 at 12:36:05 PM
Page generation time: 1.4889
