81 Users Online (80 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Exporting Layers Overlapping Lines
Mon, Oct 29, 2007 at 10:39:51 AM | Exporting Layers Overlapping Lines
superelboogie
Hi. I am wondering how to make it so that when I export to a dwg that ALL the lines export. For example. We have a Tub with Surround that is set up against the Stud Line of the wall. When we export the and then hide the Plumbing Fixtures Layer, there are now no Wall Lines where the Tub was. How do I set up my layer exporting to keep all the lines and not take out lines that are behind other lines?
Thansk a Ton!
Mon, Oct 29, 2007 at 11:24:00 AM | Exporting Layers Overlapping Lines
Change your view from hidden line to wireframe.  You may also want to turn on your plumbing and the turn that layer off in AutoCAD if you need to.
Imported layers still active when exporting
Fri, Feb 26, 2010 at 8:44:41 AM
Keep .dwg Layers when exporting .rvt to .dwgPlease
Wed, Feb 24, 2016 at 9:28:00 AM
Turning off Layers when Exporting to Cad
Wed, Nov 5, 2008 at 6:06:37 PM
exporting demo layers
Sat, Apr 21, 2012 at 8:15:27 AM
overlapping pads - is it possible?
Sat, Jul 28, 2018 at 2:00:33 PM
Page generation time: 0.5039
