Forums >> Revit Building >> Technical Support >> Sketching Mode
Wed, Oct 24, 2007 at 6:12:58 PM | Sketching Mode
rgvjr
Help...What visibility parameter is controlling the display of the sketching lines (pink) when it is not visible during the sketching mode.   When I start putting lines in it gives a warning to check visibility parameters..... Some views are behaving alright but I can't get it some view even if I apply view templates made from functioning ones....thanks for the help.
 RGV
Thu, Oct 25, 2007 at 3:57:16 AM | Sketching Mode
KingRevit
4 Stars: 12 Votes
vv
model catagory
lines
make sure lines it ticked, it doesn't matter if the sub catagories are turned off once the main lines button is ticked
Fri, Oct 26, 2007 at 7:17:08 AM | Sketching Mode
KingRevit
4 Stars: 12 Votes
also i was training a new user yesterday and they got the exact same problem as you. you may of done the same as them.
did you move your elevation sympol in a plan view. if you did you may of only moved one of the 2 parts your meant o move.
easiset way to fix it is delete your elevation thats giving you a prolem and place in a new elevation.
hope this helps
Fri, Oct 26, 2007 at 1:58:22 PM | Sketching Mode
rgvjr
Thanks so much mate..i got it.  You're right had some something to do with the elevation symbol....cheers.    rgvjr
Can I render in Family mode?
Mon, Mar 29, 2010 at 6:37:04 AM
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:56 PM
Sketching programmes
Mon, Jan 16, 2012 at 3:11:46 AM
Roof design problems
Tue, Mar 10, 2009 at 11:36:32 AM
Filled Region Sketch Mode
Tue, Nov 17, 2015 at 1:28:34 PM
Page generation time: 2.6309
