62 Users Online (61 Members):
Forums >> Revit Building >> Technical Support >> WORKSET - problem moving elements to the appropriate worksets PLEASE HELP
10 Posts No Rating |
To create a central file I have enabled worksets and added user-created worksets (floors, roofs, furniture, etc.). After that when I am trying to move elements to the appropriate worksets by elements property under Identity Data it does not show user-created worksets.other then workset1. I am using Revit Architecture 2008. Please help. Thanks
There was a problem with my REVIT Architecture 2008. I had to reinstalled it and now it just works fine with the workset properties. Thanks for your help.
2 Posts No Rating |
Right-click on the element and select make element editable. Now the pulldown should be enabled and you can change it to the appropriate workset
WORKSET - problem moving elements to the appropriate worksets PLEASE HELP |
Tue, Oct 23, 2007 at 2:36:13 PM
linked file elements on host workset...help |
Fri, May 4, 2012 at 5:46:58 AM
Cant Delete one of My worksets...please help |
Thu, Feb 14, 2019 at 1:48:12 PM
13
Worksets Problem! |
Mon, Mar 25, 2013 at 8:35:25 AM
Editing elements of locked worksets |
Sat, Mar 7, 2009 at 10:39:42 AM
Members: | 2016908 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
