58 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Demolition Lines Scale wrong / not showing with components.
Mon, Oct 22, 2007 at 9:55:09 AM | Demolition Lines Scale wrong / not showing with components.
mflure
Greetings,
Working with Revit System Series (2) CryingBut only using the Building part for now).  Working with my demolition plans and every time I try to show a sink or toilet component or something similar (not necessarily plumbing fixtures) the dashed linetype doesn't show up, only on long lengths of walls and such.  Is there a way to override the linetype by object for demolition to show that indeed the object is demo'ed?  The linetype works fine for my walls and doors, but for smaller line lengths in my components they don't.  Your help is greatly appreciated.
 Thanks in advance.
 Mike
Camera View not showing demolition lines dashed
Wed, Dec 11, 2013 at 2:24:15 PM
after revit export to pdf the file is wrong scale
Sat, Nov 20, 2010 at 10:54:04 PM
Calculate Demolition
Fri, May 8, 2015 at 3:56:11 PM
Section Lines not showing up on a plan
Thu, Jan 8, 2009 at 9:32:28 AM
Scale extrusions, solid, components
Sun, Oct 14, 2018 at 9:10:50 AM
Page generation time: 1.0749
