Forums >> Revit Systems >> Technical Support >> RENDERING ISSUES- components become transparent.
5 Posts No Rating |
I recently rendered my kitchen view and the convection oven and pantry became transparent when rendered although they had selected accurender materials. if anyone knows how to fix this issue please contact me on my home email of venturebro24@gmail.com thank you sincerely, Mike Jarasz
You have something not set correctly. Are you sure the component is set correctly in the model (NOT JUST IN THE FAMILY)? In the project, select materials and verify there. Are you sure the library that contains the description is linked to the file? In the project, select materials, then click on the accurender selection. If the library is not linked, it will tell you.
I had this same issue when I was rendering a view. Try turning off (unchecking) view culling in the settings menu on the rendering tab. This should make the items turn back on that you need.
stanmpd
Belz A&C
Memphis, TN |
5 Posts No Rating |
THANK YOU STANMPD turning off the cullings worked wonders on my raytracing now i just need to find a way to render at 1000 dpi quickly. lol
Send all your co-workers to get coffee then link to their machines....hahaha Glad I could help
stanmpd
Belz A&C
Memphis, TN |
Windows are transparent. I want to make them toned when rendering |
Thu, May 15, 2008 at 2:27:09 PM
Glass keeps rendering black not transparent |
Mon, Jan 23, 2006 at 4:01:42 AM
Rotating components, placing flanges, compentents are transparent - HELP |
Thu, Feb 16, 2012 at 9:38:36 AM
Transparent textile in rendering |
Thu, Jan 6, 2011 at 8:43:05 PM
rendering windows in 2009 |
Wed, Aug 27, 2008 at 8:35:02 AM
Members: | 2115663 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
