101 Users Online (100 Members):
Forums >> Revit Building >> Technical Support >> 2D and 3D Grids
5 Posts No Rating |
I understand how 2D & 3D grids work. I've gotten into an existing project and am unable to set grids from 2D to 3D. The 2D symbol appears black not blue when the grid is highlighted, and the Reset to 3D option on right click is greyed out. How do I get back to 3D grids, please? Thanks. -Barney
5 Posts No Rating |
Solved: If the end of the grid (or any datum, actually) lies outside the model crop region you are not allowed to change 2D extent to 3D. That's documented in RA 2008 User’s Guide, para on “Resizing Datum Extent Controls.” Solution is to temporarily turn off the crop region, make your extent change, and turn the crop back on.
Grids at an Angle in Plan don't display in Elevation |
Thu, Apr 26, 2012 at 2:44:38 PM
new user - copying grids to other levels |
Mon, Dec 6, 2010 at 3:06:35 PM
multiple scope box for grids |
Tue, Sep 1, 2015 at 8:35:46 AM
DIMENSIONing GRIDS - on plan view |
Thu, May 26, 2011 at 1:33:19 PM
Lock Columns to Grids |
Fri, Nov 2, 2007 at 6:33:27 PM
Members: | 2042270 | Objects: | 23026 | Forum Posts: | 152217 | Job Listings: | 3 |
