Forums >> Revit Building >> Technical Support >> Walkthrough avi export - please help
5 Posts No Rating |
Hi. I'm new to these forums so thanks in advance for your help. My problems is with a walkthrough I'm trying to do of a house I've done in Revit 7. The preview of the walkthrough in Revit is fine, but once I export to avi (even using hidden line and not Accurender option), every time the camera turns a tight corner or goes through or touches a wall surface the video zooms out and then back in again. This is very undesirable as in a house you may need to turn the camera a number of times, so you end up getting your animation zooming in and out like crazy. Is there a setting somewhere to turn this off? Please help.
Darryl
5 Posts No Rating |
has nobody seen this problem before. I still have not solved it.
I'm not sure why you would be having these problems, but do suggest reading through this thread: http://www.revitcity.com/forums.php?action=viewthread&thread_id=583 . I have outlined the process of setting up a walkthrough there. It may be of some help to you.
5 Posts No Rating |
Thanks for the tip, but I've already looked at that. The problem does not seem to be in Revit itself, as the walkthru is fine when I advance it frame by frame in Revit. Its when I export it to avi that the resulting video then displays these characteristics that I outlined in my first post. Its not the codecs, as I've tried different ones and different machines with the same result.
I'll keep on trying.
If you can, zip up the file and post it here. (If its too big, send it to max@lloydhome.co.uk and I will have a look). Can't really see why you should be having these problems?
walkthrough will not export |
Tue, Jan 13, 2009 at 9:45:31 AM
exporting walkthrough to avi |
Wed, Apr 25, 2007 at 5:20:46 AM
recover failed .avi file from walkthrough |
Thu, Apr 25, 2013 at 9:49:31 AM
exporting avi |
Sat, Nov 19, 2005 at 1:12:51 PM
Walkthrough Export - White Border |
Tue, May 22, 2018 at 1:20:30 PM
Members: | 2104043 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
