38 Users Online (37 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Building 2008-3 hole countertop
Tue, Oct 16, 2007 at 9:26:56 AM | Revit Building 2008-3 hole countertop
johnm
I am trying to modify a default countertop to contain three openings.  I can get the outside two openings to be constrained to a constant distance from the sides, but I cannot constrain the middle opening.  I want it to always stay in the middle.  I've tried formulas, setting the distance from each end as equal, setting the distance from the opening centerlines as equal, etc.  Commonly I get errors saying that adding a constraint would overconstrain the family.  I'm sure this is something relatively simple I'm missing.  Any ideas?  and thanks!
Tue, Oct 16, 2007 at 10:09:20 AM | Revit Building 2008-3 hole countertop
LIZARD2806
3.5 Stars: 7 Votes
I have found constrainign things to reference planes instead of each other produces less errors.  In your countertop situation, you would add a reference plane to represent the centerline.  Constrain that to be centered on the length of countertop, then contrain the holes to be constrained to that line (either on it or x inches to either side).  I think that might work for you.
**Using Revit Architecture 2009, 2011, and 2012**
Tue, Oct 16, 2007 at 10:14:09 AM | Revit Building 2008-3 hole countertop
johnm
AHHH!!!  I think that may have been part of my problem.  I wasn't constraining the reference plane correctly.  Let me look into that a little more.  What you say is making sense, so let's see if I can make it work.  Thanks!
Tue, Oct 16, 2007 at 2:02:05 PM | Revit Building 2008-3 hole countertop
johnm
Lizard2806, Thanks for the help.  That was the problem.  I had the reference lines set to be relative to each other.  Don't know why that didn't work, but when I set them to be relative to the reference lines for the ends of the cabinet, it fixed the problem.  The only additional oddity I had was the symbolic circle for the cutout in plan view wouldn't move, but I deleted it and redrew it and problem solved.  I think I'll try it out a little more and upload it here in case someone else wants to use it too.
Can't get VOID to cut my countertops...
Fri, Feb 25, 2011 at 1:41:45 PM
Cutting countertop for sink
Tue, Apr 15, 2014 at 5:21:33 PM
Countertop Invisibility
Mon, Jan 5, 2009 at 1:46:40 PM
How do I add a countertop to the Base Cabinet - Corner Unit Angled?
Tue, Mar 28, 2006 at 3:39:11 PM
Anyone ever put a countertop on a wall as a sweep? Anyone?
Wed, Nov 15, 2006 at 4:15:42 PM
Page generation time: 1.9777
