104 Users Online (103 Members):
Forums >> Revit Building >> Technical Support >> using array on wall reveals - 2008
![architurk Avatar](user_avatar/24361.jpg)
![3.5 Stars: 3 Votes](/images/stars_3.5.gif) |
i use 2008 version i needed reveals on a L shaped thick wall 1- i tried to do it within wall type edit, but at first adding reveals there didnt seem practical to me (i have expected sth like array, or ability to give distance from the previous reveal: because the position of there reveals might change afterwards) and also it didnt look fine at endings of my "edited profile" wall openings. 2- i tried to make it host sweep/wall reveal. i make the reveal turn the corner (by adding another reveal at the same level or by extending reveal till the edge and changing sweep returns) but when i apply array (i found out that array might be applied only on section view?!?) on this L shaped reveal it only multiplies one segment. what do i do wrong? thx for ur timesaving helps!!!
![4 Stars: 12 Votes](/images/stars_4.gif) |
easiest way i find for arraying wall reveals is to place in your reveals. select your one of your reveals in an elevation view use isolate catagory. even though you can see them you can still select them drag a box to select all the reveals you want then use the array tool.
Edited on: Tue, Oct 16, 2007 at 11:26:59 AM
i am sorry but it seems i couldnt expose my question clearly, so please take a look at attached rvt file. there i have a wall reveal component and THERE IS NO WAY I CAN NEITHER COPY NOR ARRAY that reveal. any quick reply would be greatly appreciated thx
Edited on: Wed, Oct 17, 2007 at 1:20:33 AM
delete your window then array your reveal then put the windows back in. or place in new reveals at the requires location.
Wall Reveals |
Mon, Jul 9, 2007 at 11:55:45 AM
Precast panels and vertical reveals |
Thu, Jan 17, 2013 at 9:38:52 AM
Wall Reveals |
Wed, May 19, 2004 at 10:39:26 PM
Reveals and Voids |
Fri, Apr 4, 2008 at 6:12:38 PM
Vertical wall reveals |
Fri, Jul 21, 2006 at 4:54:55 PM
Members: | 2076447 | Objects: | 23116 | Forum Posts: | 152268 | Job Listings: | 3 |
