68 Users Online (66 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Pin Position
Tue, Oct 16, 2007 at 2:46:03 AM | Pin Position
vector23
vector23 Avatar
2 Stars: 16 Votes
what's the difference between pin position and locking
a dimension? don't they both create a constraint the same?
when would you use one instead of the other?
Tue, Oct 16, 2007 at 4:01:44 AM | Pin Position
KimWong
KimWong Avatar
3 Stars: 2 Votes
When you import a dwg or image into Revit, use the PIN to pin down its position. This is to avoid accidentally moving it if you are tracing over the info. As for contraint, you basically "locked"  e.g the dimension, from being changed. So if you move the wall, the dimension remains the same. In some cases, Revit will warn there is a contraint attached to the object. I don't think you can contraint a file you import into Revit.
G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong.
locking the walls in other levels
Fri, Jul 28, 2006 at 7:29:09 PM
When to pin, When to lock - Best practices
Tue, Nov 27, 2007 at 8:43:12 AM
Can't pin linked file
Fri, Oct 16, 2009 at 11:50:42 AM
"Lock/Pin" Linked Architectural Model
Fri, Feb 11, 2011 at 10:13:53 AM
Imported image troubles, can I "pin" it?
Wed, Nov 19, 2008 at 2:03:42 PM
Page generation time: 0.2345
