56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Material Parameter
Mon, Oct 15, 2007 at 4:01:34 PM | Material Parameter
dlrenier
Hey ive noticed that the families in the imperial library come with a material parameter that can be changed in projects but i cant seem to figure out how this is created.
Mon, Oct 15, 2007 at 6:17:41 PM | Material Parameter
ArchWestCY
4.5 Stars: 7 Votes
This perameter exist in each solid.  If you look at a family that is already created, you will find that each solid has a parameter for material.  If you look at a solid's properties will will notice that the material value is greyed out, and to the right you will see a little equals = sign.  When each of these solids were created, instead of assigning a material in each properties dialog they have assigned a parameter that can be adjusted from the Family Types dialog.  This is how the material is adjustable inside your project.  So, if the family wasn't orginized real well during its construction, then you might not have control of the materials inside the project.  If this is the case, you can simply edit the family, then select each peice and open its properties dialog.  Click on the little equals = box to the right of the Materials Value, click Add Parameter, then give the parameter a name you will recognize later.  You should also change the Group Parameter Under: to Materials and Finishes.  Fix all of the solids to have a material parameter that you can access from the Family Types, and Load into Project.  Your good to go.
 Hope this helps
ArchWestCY
Mon, Oct 15, 2007 at 6:27:24 PM | Material Parameter
dlrenier
ahh yes this works perfectly. props to you. thanks a lot!
Fri, Oct 3, 2008 at 2:49:40 PM | Material Parameter
dprado
I'm trying to produce a C&M index similar to the one attached i was trying to add a parameter to my materials, one option for Leed information, another for Color, and Location. Previously i need a parameter "Discipline Name" to organize my materials Carpet, Ceramic Tile, Metal,... i didnt' it so fast that i don't remember what i was clicking.  Please help how can i create another material parameter.  i have tried the following (image3) , i don't know what i'm doing wrong.
Material Description to be scheduled
Fri, Sep 19, 2014 at 9:18:13 AM
Shared Material Between Families
Mon, Aug 31, 2015 at 11:21:41 AM
LEVEL Parameter in Material Takeoff
Fri, Apr 11, 2014 at 7:54:39 AM
Door Panel Material Parameter Selection
Wed, Nov 19, 2008 at 4:34:13 PM
material tagging a family
Mon, Apr 15, 2013 at 4:12:47 AM
Page generation time: 0.9512
