48 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Room and Area Problems
Mon, Oct 15, 2007 at 1:28:19 PM | Room and Area Problems
moreno2000
Why does Room/Area in existing phase get deleted the moment you demolish the walls? i want to show both Room /  Area in Existing and New Construction. my view phase are set correctly and my Elemental phase are set to the right phase.
Tue, Oct 16, 2007 at 5:37:09 AM | Room and Area Problems
KingRevit
4 Stars: 12 Votes
because once you demolish a wall revit doesn't count it, it actually is the way i belive it should work, so when you demolish an internal wall revit now counts the 2 rooms as 1.
the work around for the way you want it to work is place a wall separation line along the wall before you demolish it.
Tue, Oct 16, 2007 at 8:49:33 AM | Room and Area Problems
moreno2000
I tried this method with the seperation lines. What happens with that is the rooms now showing up in demo plan and in the new plan. What i need to do is for the existing room to show up in demo plan and the new room to show up in new plan without it causing conflict with each other. I'm gonna check in 9.1 Revit because i'm sure it worked then and don't know why it is not working.
Thanks,
moreno2000
Tue, Oct 16, 2007 at 11:14:17 AM | Room and Area Problems
KingRevit
4 Stars: 12 Votes
i think your problem may be that you are not in the right phsae when you place in your room.
go to view properties
and under phasing going to phase and set the phase to existing before you use the room tool
changing the scale of my room and area tags with the scale of my area plan.
Fri, Oct 22, 2010 at 10:38:38 AM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
room area calculation
Thu, Jan 15, 2009 at 5:51:20 AM
ROOM AREA VARIES DEPENDING ON THE DISTANCE FROM PROJECT ORIGIN
Thu, Jul 12, 2012 at 8:24:17 AM
room area calculations
Tue, Nov 4, 2008 at 3:48:50 PM
Page generation time: 0.5933
