69 Users Online (68 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> pi in formulas?
Wed, Oct 10, 2007 at 4:41:35 PM | pi in formulas?
johngfielden
Is there any way of using pi in formulas?
I'm trying to determine the central angle of an arc given the chord length and the radius.  The formula I found returns radians.  so I need to convert that to degrees.  Any suggestions?
Thanks.
Thu, Oct 11, 2007 at 6:32:49 AM | pi in formulas?
coreed
coreed Avatar
4 Stars: 16 Votes
there are 0.0174532925 radians in 1 degree
HTH
Edited on: Thu, Oct 11, 2007 at 6:36:19 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, May 30, 2012 at 5:59:15 PM | pi in formulas?
dphunk
I'm having a similar problem. http://youtu.be/UCsF4hEbGZQ is a great video on weaving. it's works great in 2012, but I have 2011. it has everything to do with degrees and radiants. in 2012 you can change the measument type of a point to be a angle, rather then radiants which is the only option in 2011. the formula used in the video is below, and I want to value of the formula in a to be in angle 1, which is the hosted paramater for the point on a circle. but if I put a as the value, it's the dreaded inconsistant units message. anyone have any ideas?
Thu, Sep 13, 2012 at 6:20:57 PM | pi in formulas?
bruff730
pi()
Understanding Formulas
Tue, Nov 16, 2010 at 1:36:05 PM
14
to import shared parameters with formulas.
Fri, Jun 20, 2014 at 7:19:05 AM
Parameter Formulas
Wed, Mar 21, 2007 at 12:48:43 PM
Formulas for Dimensions?
Mon, Jan 9, 2006 at 9:59:53 AM
Conditional Statements in Formulas
Wed, Jun 21, 2017 at 3:50:17 AM
Page generation time: 0.2235
