82 Users Online (81 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> plan/field of view
Mon, Feb 14, 2005 at 6:56:33 PM | plan/field of view
aabrmn
some of my plan views are showing the floor as well as the linked dwg of the level below. some not. I have been trying to fix this with view properties/view range but with no success. I surely have to investigate this better and I am afraid that trying to tweek the view I just changed some parameter to the wrong value. I was wandering if there is any way to reset a view to it's initial state without deleting the level (now that a floor, stairs and walls are linked to it). How do you guys manage this? What is it that I am missing? Thank you very much. Post edited on 2005-02-14 19:27:15 Post edited on 2005-02-14 19:44:35
Mon, Feb 14, 2005 at 9:06:39 PM | RE: plan/field of view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
If you include a screenshot of exactly what your talking about i may be able to get a better idea on how to fix the problem? To create a new floor plan with default settings goto view-->New-->floor plan then select the level you wish to make the floor plan of. You've obviously linked a dwg in as a model element, check to see if you have imported it in at the correct elevation? If you only want it in one view, re-link with current view only ticked to import as a drafting element. HTH.
Mon, Feb 14, 2005 at 10:00:37 PM | RE: plan/field of view
aabrmn
Mr Spot, I will follow your advice as soon as I get back to my desk. Thank you very much.
Model it for field installation or for plan view on my sheets???
Tue, Jan 11, 2011 at 9:16:58 AM
Entering camera field of view numerically - Revit 2010
Thu, Aug 12, 2010 at 9:58:48 AM
Editing Walkthrough Cameras field of view (FOV) in Plan View
Fri, Jun 26, 2009 at 1:17:38 PM
help "painting a field" ?
Wed, May 16, 2007 at 8:40:31 AM
How to see the upper floor (beams,floors) in plan view?
Tue, Jun 14, 2005 at 4:37:20 AM
Page generation time: 1.2178
