44 Users Online (43 Members):
Forums >> Revit Building >> Technical Support >> Imported Drawings Visibility Issues
2 Posts No Rating |
I'm trying to supplement the Revit section cuts by importing some CAD drawings. When I try importing/linking the drawing this shows up: None of the created elements are visible in Section: EAST-WEST. You may want to check the active view, its Parameters, and Visibility settings. Then the CAD drawing does not appear. I've looked through the view properties without any success. Any suggestions? Revit Architecture 2008
Make sure you've checked "Current View Only" when importing the CAD file.
2 Posts No Rating |
Thank you...That seems to work well along with not using the Auto-Detect in the Import Units
imported DWG visibility |
Fri, Apr 13, 2007 at 12:26:22 AM
Delete old imported cad drawings |
Fri, Jul 10, 2015 at 8:15:25 AM
Imported .dwg File Visibility Settings |
Mon, Mar 14, 2011 at 5:29:06 PM
How to apply Visibility/Graphics Options to other drawings. |
Tue, Jan 10, 2017 at 12:54:10 PM
Blue Line - Visibility/Graphics Issues in Floor Plan |
Tue, Nov 6, 2018 at 7:56:57 AM
Members: | 2056641 | Objects: | 23074 | Forum Posts: | 152327 | Job Listings: | 3 |
