105 Users Online (105 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Painting Single Walls
Mon, Oct 8, 2007 at 1:13:20 PM | Painting Single Walls
skarbo41
I'm having trouble painting Individual walls in Revit. My problem is that when I use the paint command I can highlight individual walls but how do I know when it is painted (meaning when I render the structure you can see the color)? and how can you change colors in the paint command?
Wed, Oct 17, 2007 at 9:10:35 AM | Painting Single Walls
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
When using the paint tool you are applying a material to the surface of an object. In order to see the color you need to set the material to have a shaded color. Usually when selecting an Accurender material as a texture, the program will adjust the shade color to match the base color of the material. Also note that you can only see the color fills in shaded modes.
Painting seperate parts of walls?
Wed, Feb 4, 2015 at 8:22:45 AM
painting walls
Mon, Feb 20, 2012 at 9:35:26 PM
painting walls
Tue, Jul 5, 2011 at 6:29:49 AM
Painting walls across phases
Thu, Dec 26, 2013 at 12:36:58 PM
painting schedule
Tue, Jun 25, 2013 at 7:27:09 AM
Page generation time: 0.7315
