68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Export to Autocad 2005 (Hatch Patterns Go Missing)
Mon, Feb 14, 2005 at 6:13:59 AM | Export to Autocad 2005 (Hatch Patterns Go Missing)
rick_tiger
Hello People I have found that Revit 7 does not export the elevations as well as it did in earlier versions. For example, if I am using a wall with a surface pattern (eg Brick or Concrete pattern), some of the elevations have the pattern missing and some times this happens to the roof with a pattern. I find that I have hatch these areas in Autocad to get by, I realise that I can use the sheet system in Revit, but at the moment I need to share these files with other consultants who only use autocad. Is anyone having the same problems or is there solution to this problem. Richard
Custom Hatch Patterns
Thu, Dec 23, 2004 at 3:00:33 PM
Hatch Patterns
Thu, Sep 14, 2006 at 10:05:03 AM
Hiding Hatch Patterns [ 1 2 ]
Sat, Aug 29, 2009 at 8:12:26 AM
15
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:03 PM
Stone Hatch Patterns - Looking for a good source.
Sat, May 4, 2013 at 4:59:25 AM
Page generation time: 2.2942
