59 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Wishlist >> Matchline tool
Fri, Oct 5, 2007 at 2:00:50 PM | Matchline tool
mjbednarczyk
mjbednarczyk Avatar
3 Stars: 2 Votes
Well the matchline tool looks like a good start but it needs work. What I need to do is be able to define a matchline for 1/4" scale plans and a match line for 1/8" scale plans. I can create a sub category for both under match line but i can not figure out how to place the match lines assigned to the two different subcategories. If I were abe to I could contorl them in visibility graphics.
Mon, Oct 8, 2007 at 8:53:38 AM | Matchline tool
laurabh
Use Visibility/Graphics overrides in View Templates - one for 1/8" and one for 1/4", and then set these as default view templates to the respective views and apply.
Wed, Dec 12, 2007 at 2:46:26 PM | Matchline tool
charlotte240
charlotte240 Avatar
3.5 Stars: 3 Votes
mjbednarczyk, you do not say what version of Revit you are using.I will assume Revit Architecture 2008good tip laurabh, to make a "view template" with the annotation matchline turned off in 1/8"  and on in 1/4" in the VG.the other thing I wanted to add was after you make a matchline, also add a "View Reference" to both ends of the line .   This parameter will allow you to click on it and be taken to the connecting corresponding view."See A-101.1 for south plan" To do it:Go to a view that the matchline is drawn in , and from the "VIEW" menu, right below, "matchline" you will see "View Reference"This is in Revit Architecture 2008
CRI
Plan views on a sheet with matchline
Thu, Sep 21, 2006 at 7:26:11 AM
Matchline Graphics - Revit Architecture 2008
Wed, Sep 24, 2008 at 4:10:31 AM
Step matchline with crop region?
Wed, Sep 5, 2007 at 5:05:22 PM
Annotation lines outside the crop region
Wed, Jan 14, 2015 at 12:53:07 PM
How can we print with matchline command?
Thu, Dec 11, 2008 at 8:22:29 AM
Page generation time: 0.6067
