45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How to copy over entire project
Thu, Oct 4, 2007 at 2:32:54 PM | How to copy over entire project
jimij
Hello, I've been on this forum for some time but I've never posted before so hello everyone, appreciate all the help over the last year whether you knew you were giving it or not!
Here's the question, seen it asked on here but can't find an answer...How do I copy an entire project from one file to another. I have a new template file and would like to move an older unfinished project over so that I have everything including all views and section cuts etc. Oh yeah this will also be a move from 9.1 to 2008. Any Ideas are welcome, Thanks
 -Jimij
Fri, Oct 5, 2007 at 12:16:55 PM | How to copy over entire project
jimij
Really wow nothing huh, seems like this should be easy, wonder what I'm missing
Fri, Oct 5, 2007 at 12:56:08 PM | How to copy over entire project
jron
I was able to combine two projects into one with this help that recieved from our another Revit. Hope this helps.
Fri, Oct 5, 2007 at 12:58:24 PM | How to copy over entire project
JHanby
3.5 Stars: 3 Votes
jimij, I am trying to find out if you can bind linked revit models in 2008.  Maybe you could try to link the old model into the template and see if you can bind them.  Worth a try and it might help us both out.  Smile  The only other thing I can think of would be to copy and paste the elements but you wouldn't get all the details and views all ready set up in the old model.
Tue, Oct 9, 2007 at 9:44:40 AM | How to copy over entire project
jbaysinger
3 Stars: 4 Votes
I have an idea, but I'm not sure if it will work.  What you can try is:  Upgrade your project to 2008.  Open up your new template file and your project in the same window, so you can go to the window tab and switch from project to project.  You might be able to go into your template file and in the browser you can copy stuff over from the template file into your project.  You will not be using your template file for the project, just stealing stuff from it.  You probably wont be able to copy views over, but you should be able to copy over families and schedules and stuff like that.  Let me know if this works for you.  Good luck!
Wed, Oct 10, 2007 at 7:04:38 PM | How to copy over entire project
jimij
Hey thanks for the responses, I think the .doc file sounds like it has the best aproach, link in the old model then bind it (new in 200Shadey I'm going to try it, it may not be perfect but if it gets me close I'm happy, thanks again everyone!
-Jimij
Wed, Nov 7, 2007 at 9:10:06 AM | How to copy over entire project
burke424
I was able to bind the model items as discussed in the .doc file, but how do you get all th eviews and everything else that are already on sheets?
Wed, Nov 7, 2007 at 9:23:59 AM | How to copy over entire project
jron
Seeing that you have the new model, what I had to do was just create the same views again in the new project.
I know it sounds redundant but I was able to save alot of time by not having to redo everthing.
HTH
John
Wed, Nov 7, 2007 at 10:38:32 AM | How to copy over entire project
burke424
That's what I thought but I was hoping someone had found a better way.
Thanks
Mirroring entire project- "copy" check box greyed out?
Sun, Apr 23, 2006 at 6:44:58 PM
Move half of entire project down vertically
Tue, Aug 4, 2015 at 10:35:43 AM
how to hide an entire level
Thu, Aug 19, 2010 at 4:17:48 AM
copying an entire building without mess ups
Mon, Nov 17, 2014 at 10:16:42 AM
Copy Legend to New Project?
Wed, Feb 20, 2013 at 3:37:11 PM
13
Page generation time: 1.4732
