49 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Problem with Maps
Thu, Oct 4, 2007 at 4:06:33 AM | Problem with Maps
Cobra007
I am working as a trainee in a firm where we have done a project using revit and the materials were applied in one system, but later due to some reason i was asked to work on the same file in another system, but then i could not render it from the second system as the maps assigned were in the other computer, i shifted the whole rendering folder from the earlier system to the later one where i was working recently but now the projects which were done in the second system aslo have been misplaced of the maps and the projects done in the second system are also not being rendered properly. can anyone guide me with this and alo can any one let me know how to render via network, is that facility available in revit?
 Thanks in advance.....
Mon, Oct 15, 2007 at 12:00:49 AM | Problem with Maps
eldados
eldados Avatar
4.5 Stars: 8 Votes
if you click on Settings --> Options... and go to the Rendering tab, you will find all your paths in there. you can put a path to a network location should you wish.
Integrator
KarelCAD
Material maps
Tue, Oct 12, 2004 at 7:01:05 PM
Maps and Render Times
Mon, Feb 8, 2010 at 3:54:44 PM
Procedural Maps
Fri, Sep 28, 2007 at 10:45:29 AM
HELP With Bump Maps!!!!!!!!!!!
Tue, Aug 28, 2007 at 8:59:35 PM
bump maps in new materials
Wed, Dec 14, 2005 at 5:43:26 PM
Page generation time: 8.4866
