Forums >> Community >> The Studio >> Architectural fonts
5 Posts No Rating |
I'm looking for the famous ARchitxt font or another decent architecural hand type font. Any recommendations, samples and sources??
Revit, doest not support SHX files, so trying to use the Archtxt font won't work. Revit only supports True type font files. There are a number of websites that you can go to ckeck out fonts and pruchase.
http://store.adobe.com/type/main.html
www.fonts-online.com
www.lineotypes.com
http://www.philsfonts.com/otlist.html
A good font to use is GraphiteŽ Std Regular, another is Handsf Single.
Attached is the ttf file for handsf Single. Try it out if you like.
5 Posts No Rating |
Thanks Arno
Handsfn might work... I'm trying to track down Architxt.ttf which is in some of the annotation families here and was discussed in some older forum links. Even pay sites don't seem have this particular one.
I'll keep searching. It is similar to an shx that we use on acad
Architxt.ttf is available and I have it on my computer at home, I will bring it in for you, the only thing it it really does not look like the shx font that I think you are talking about. The Handsf Single font is closer to the Architxt shx that you are talking. Let me know if you still need it.
whoa..
I have the architext and ARchitxt fonts loaded and they work just fine they are of course TTF I could send to you if you wish.
Do they look, architecturally speaking or are they looking like simple txt from autocad. If they look architecturally speaking I would love to take a look if you don't mind. Thanks
5 Posts No Rating |
As Arnosandoval has recommended, Handsfn.ttf looks pretty good but I wouldn't mind a copy of architxt.ttf too for comparison.
I found the architxt.ttf that looks like simplex from acad also, out in the deep dark crevises of the internet.....its scary what you might find out there...
Mtropper,
Curious where you able to get the Architext font to work?
timOthyj,
Is it possible for you to post those two fonts, it's something that I just want some clarification. Thanks in advance.
Try using Stylus BT which is a standard Windows True Type font. You won't have to worry about sending the font with your files to other users. It will give your drawings a hand lettered look and is very legible and free.
Thanks, I am aware of the Stylus BT, it's a nice font, and has worked in the past, but not quite what I'm looking for. Really what I would like to see happen is Revit either accept shx fonts or have them include some Architectural fonts with the software. That is just me.
5 Posts No Rating |
Just an update..
We started to use handsfn.ttf. It seems to do the trick. It looks good but its scale is kind of funky. What ever size you need it needs to be reduced about 75%.
Shx would be nice for all of us former Acad junkies...
69 Posts No Rating |
We use this ARCHITXT font and it works fine except sometimes when you export PDF files!
JStewart,
Thank you. This is the font that I was looking for. It looks great, and am looking forward to using it on my projects.
1 Posts No Rating |
"We use this ARCHITXT font and it works fine except sometimes when you export PDF files! " Awesome! I have been looking for this!!!! I owe you one.
I say thanks to old threads... i've been looking for this font
