63 Users Online (62 Members):
Forums >> Revit Structure >> Technical Support >> Curtain wall visiblilty
25 Posts No Rating |
When I try to draw a curtain wall I get this warning : None of the created elements are visible in Structural Plan: LEVEL TWO View. You may want to check the active view, its Parameters, and Visibility settings, as well as any Plan Regions and their settings. What can I do to make curtain wall visible?
![](https://ci6.googleusercontent.com/proxy/KRnLbkX-hpqUHxK_ZTtWofWmS__jEx4Cbab_kYXcMqSsyTAi7DoEs3GNXPckBI6B7c9roTk7bfqgrf5841GtS3jIkBthAImpS4fqTSvL5c2hbdOvi496IgsAK6lUkoCAkY7TOr9BPiLwOPM577B6KuS8uEb-ZExUl44h-nnloL3VT2OcytdMNxRojyFuZr3gD8x6uqRDSI5Zp4I=s0-d-e1-ft#https://docs.google.com/uc?export=download&id=0By2tt3u4fCIpMWNBMkFtV1FoMDA&revid=0By2tt3u4fCIpMG40YUdVOTBlbGFCQzJ0U2V0N3FJMWVudlZrPQ)
![robinballew Avatar](user_avatar/12071.jpg)
![3 Stars: 4 Votes](/images/stars_3.gif) |
In structural plans curtain walls are not visible because they are not structural. Change the setting under View Properities to Architectural.
----------------------------------- BallewDesigns.com |
that worked. Thank you
2 Posts No Rating |
I am having the same problem. When I change the discipline to Architectural or Coordination, my framing becomes invisible. I also noticed that strangely some of the curtain walls do appear.
Curtain Wall Panel to Curtain Wall Door |
Curtain wall not cutting through moulding |
Thu, Oct 22, 2015 at 2:53:44 PM
Splitting a curtain wall to change the type of wall it is |
Thu, Aug 6, 2009 at 12:46:42 AM
Can't Put Curtain Wall Inside Stacked Wall??????? Help Needed |
Thu, Jan 24, 2013 at 8:06:06 PM
curtain wall |
Sat, Jan 10, 2009 at 10:01:35 AM
Members: | 2022358 | Objects: | 22975 | Forum Posts: | 152203 | Job Listings: | 3 |
