72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> vertical plywood
Mon, Dec 29, 2003 at 4:11:05 PM | vertical plywood
jb00
Hi All, Trying to make a vertical plywood fill pattern, but am not familiar enough with process to create same. I have a horizontal fill pattern, (from Acad.pat file) but I don't know what to manipulate to make it vertical, and the Revit plywood pattern I created only wants to show up horizontal. Clues for the clueless? Thx. jb
Mon, Dec 29, 2003 at 4:50:33 PM | RE: vertical plywood
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
I'm not sure how patterns are created in Autocad, but I've created some by editing the .pat text file. It's a royal pain to do it that way and I think there should be an easier way! Anyways, all that to say, I don't know how to do what you're asking other than spend hours "hand coding" it...there's probably an easier way though. There might be a piece of software out there that turns dwg's into patterns or something...
Hiroshi Jacobs
Mon, Dec 29, 2003 at 6:40:53 PM | RE: vertical plywood
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
jb, here's a link with a list of some hatch pattern generators. I think most of them cost like $45-$55 but most have trial versions. http://www.click4links.com/D11.asp?l=0011AutoCAD&l=1421Hatch_Pattern_Utilities also, here's a tutorial on making hatch patterns from scratch.. http://www.afralisp.com/lisp/hatch.htm
Hiroshi Jacobs
Tue, Dec 30, 2003 at 5:56:36 PM | RE: vertical plywood
cdsdraft
Hi JB, are you looking for a section of the veneers (on 1/8" Centers or the actual grain of the face (with biscuits)? If you have an existing Pattern, e-mail it to me and I'll manipulate it to the vert. position. Bob Post edited on 2003-12-30 17:59:01
Tue, Dec 30, 2003 at 8:01:24 PM | RE: vertical plywood
cdsdraft
jb, modified and posted as vert_plywood and plywood_vert (model and Drafting)
Mon, Aug 4, 2008 at 1:15:56 PM | vertical plywood
Thread Post Kudo! #6
clinard
Open the plywood-section detail component in the imperial library. Edit the existing fill making it a model fill. You'll have to create a new model fill. Use this hatch pattern as the .pat file that you import as custom. Use an import scale of .2 , then save it.
 NOW which ever way you draw the sheathing the plywood pattern will stay aligned.
*plywood;%TYPE=MODEL180.00000, 4.00000,2.00000, 0.00000,4.0000045.00000, 2.00000,2.00000, 2.82843,2.82843, 2.82843,-2.82843135.00000, 4.00000,0.00000, 2.82843,-2.82843, 2.82843,-2.82843135.00000, 2.00000,0.00000, 2.82843,-2.82843, 2.82843,-2.8284345.00000, 0.00000,2.00000, 2.82843,2.82843, 2.82843,-2.828430.00000, 0.00000,0.00000, 0.00000,4.00000
Tue, Jul 6, 2010 at 12:57:52 PM | vertical plywood
ros18mar
Clinard,
Followed your instructions and created a filled region with a model Fill Pattern able to rotate any way I want.
Thanks a million!
Mon, Sep 13, 2010 at 12:40:36 PM | vertical plywood
citywillsaveus
clinard -
 I  have attempted to make a new .pat file by pasting in the code that you posted, and I'm getting an error message "syntax error on line 3" when attempting to load the pattern file into REVIT as a custom model pattern. Is there anything I need to know about how the code is formatted? Thanks.
Wed, Jan 5, 2011 at 11:08:35 AM | vertical plywood
palladio1234
5 Stars: 3 Votes
clinard I also get the same problem as citywill.  Any idea whats going on?
Wed, Jan 5, 2011 at 11:16:01 AM | vertical plywood
Text in this forum may not be formatted correctly to just copy paste into a pattern file.  That is probably your problem.  Here is a plywood file:
Thu, Nov 24, 2011 at 12:37:19 PM | vertical plywood
#11
JST000
JST000 Avatar
I can't get the scale at 0.2 it give me this message (see attached screen shot) the smallest scale it will let me use is 5, which is way to big.
Any ideas on how to fix?
Fri, Nov 25, 2011 at 8:04:31 AM | vertical plywood
#12
How small are you trying to make this pattern?  It becomes a solid when it is too small.  This pattern is for detail views, not small scale views.
Fri, Nov 25, 2011 at 8:26:45 AM | vertical plywood
#13
JST000
JST000 Avatar
Just trying to use it for scales of 1 1/2"=1'-0" and 3"=1'-0". For detailing.
Vertical Plywood Hatch Pattern [ 1 2 ]
Mon, Aug 27, 2012 at 4:04:31 PM
17
Creating a horizontal recess in a vertical grooved plywood clad wall
Fri, Dec 10, 2010 at 3:49:12 AM
Custom Rafter Cut for plumb plywood and square standing seam
Sun, Dec 15, 2013 at 10:26:28 AM
plywood
Sat, Feb 12, 2005 at 5:01:51 PM
4' x 8' plywood representatiion in Revit (3d view)
Wed, Feb 10, 2010 at 7:42:34 AM
Page generation time: 0.5669
