111 Users Online (110 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Composite floor edge
Mon, Oct 1, 2007 at 5:46:31 AM | Composite floor edge
Augis
Dear All,
i need to create this type of floor edge without using in-place-familly. Is it possible?
Currently, i create in-place family with void to provide a shelf on the floor slab and add a floor slab edge.In the case the bounding profile changes, i need to re-edit all instances.
The image is attached. Revit Architecture 2008.
Mon, Oct 1, 2007 at 7:14:53 AM | Composite floor edge
I would do a floor edge sweep for this.  The profile can be whatever you want.   I use a floor edge swep to add perimeter insulation to my ground slabs.
Mon, Oct 1, 2007 at 8:29:32 AM | WWHub
Augis
Quoting WWHub from 2007-10-01 07:14:52
"I would do a floor edge sweep for this. The profile can be whatever you want. I use a floor edge swep to add perimeter insulation to my ground slabs."
it is edge sweep already, the question is how to create a bottom part together with the sweep. The floor structure does matter - it's wor working drawings.
Mon, Oct 1, 2007 at 8:38:42 AM | Composite floor edge
The floor & wall you show below your slab can be an "edge sweep"
floor slab edge
Fri, Aug 22, 2008 at 3:31:35 AM
floor edge rim
Thu, Jul 28, 2011 at 1:29:12 PM
Trapezoid shaped Wall-Foundation or floor slab-edge!! [extra reinforced rib]
Wed, Feb 6, 2019 at 7:54:59 AM
adding radius edge to floor slab
Wed, Jul 21, 2010 at 7:47:30 AM
Can Floor Slab Edge Material be different?
Thu, Dec 1, 2011 at 3:44:58 PM
Page generation time: 4.9427
