42 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Nwe user: Using Revit in Imperial and Metric units
Sat, Sep 29, 2007 at 9:14:46 PM | Nwe user: Using Revit in Imperial and Metric units
maparsons35
Hi,
I'm a new user of revit, and i don't understand why my library is only in  metric, Is there a way to import imperial library to be able to have the choise between Metric and Imperial.
 Thanks
Sat, Sep 29, 2007 at 9:47:06 PM | Nwe user: Using Revit in Imperial and Metric units
KimWong
KimWong Avatar
3 Stars: 2 Votes
Welcome to the forum. During the installattion, you must have choosen METRIC as your default project unit. By doing that all your component parameter setting will shop up in metric. To change to IMPERIAL, go to Settings > Project Units (UN) and change all your units to IMPERIAL. You have to do that each time you want to switch between Metric and Imperial. TIP: In metric setup, you can enter your unit in imperial, Revit will auto convert to imperial unit. You can do the same when in imperial too for metric measurement. Revit is very flexible here.
G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong.
Sat, Sep 29, 2007 at 9:57:47 PM | Nwe user: Using Revit in Imperial and Metric units
maparsons35
Thanks a lot,
But, is there a way to have both metric and imperial library for example have the wall in metric and imperial?
Because when a did new project and a choose imperial i don't have much option for the walls.
Thank you
problems printing in metric
Wed, Aug 13, 2008 at 9:52:13 AM
Change all units from imperial to metric without UN
Sun, Feb 17, 2013 at 9:16:15 AM
Imperial to Metric
Mon, Feb 16, 2009 at 7:35:52 AM
Imperial metric question RAC2009
Fri, Jan 9, 2009 at 11:35:51 AM
Project Units From Metric To Imperial
Fri, May 27, 2011 at 12:40:00 PM
Page generation time: 3.0787
