46 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> File not opening!
I tried to open my project file and this is the error message I got:Error message: “An Attempt was made to access model.rvt past its end.” I then have to delete the file and either use a back-up or in this case there are no back-ups and I have to start all over.
Denver, CO
Revit Architecture |
Hello same problem occured for us too...unfortunately no back up available; can any body share some knowledge about this.
Bhanu Gejjala,
VP - Project Architecture & BIM,
RSP , Dubai |
are you working out of a central file or only a local copy?
It was not made as central file but on the network drive.
Bhanu Gejjala,
RSP , Dubai |
If you don't have a local copy on your machine of the central file, you might be out of luck. To my knowledge you can't rename a *.bak file or something similar like you could with AutoCAD. Hopefully I am wrong about that and someone can chime in about it.
dimensioning opening height of linked file |
Mon, Oct 6, 2014 at 9:49:46 AM
Arched Opening Problems |
Tue, Jan 18, 2005 at 5:06:11 PM
Floor and shaft opening issues |
Fri, Nov 4, 2016 at 3:41:50 PM
error opening revit projects in revit 2013 |
Wed, Jul 25, 2012 at 8:54:57 PM
REVIT 2015 DELETE FAMILIES FROM FILE BEFORE OPENING IT - UNRECOVERABLE ERROR |
Thu, May 12, 2016 at 7:57:15 AM
Members: | 2030522 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
