Forums >> Revit Building >> Technical Support >> Quick boundary select/Magic wand?
I used to use ArchiCAD at my old job. Now I'm in Revit and when trying to create a massing, drawing lines or using filled region I am usually tracing something and just want to say 'Fill' a wall in elevation. In ArchiCAD I could hold the space bar down and click in the middle and it used a magic wand tool to find the area of the tool I'm using. Is there a way to do this in Revit? Thanks,Lorne
Denver, CO
Revit Architecture |
i know this is two years to late, but try using the tab key. You can tap it 3 times real quick to select all conecting edges of a poly line or any connected elements like walls or cad import.
Thanks Hence, Yea when I got the reminder email I didn't even remember this and I can obviously answer my own question now by using the tab key. Thanks for posting, better late than never! Lorne
Denver, CO
Hey, this is a bit off topic, but since you used Archicad (I assume you know it pretty well) when you create your custom hatch pattern, is there a way to export it into a .pat file so I can use it in Revit? Thanks for your help =)
- Core 2 Duo E8400 3ghz
- 756mb Nvidia 9600GSO 256bit
- 6gb Kingston RAM 800mz DDR2
- Windows XP Service Pack 3 32-bit
The only thing i could think of would be to export a dwg file from ArchiCAD and use that for your .pat file from autocad. I don't remember exactly how converte it after it is in autocad but i know there are post on this site that give good instruction on how to it. PS. Coming from ArchiCAD and now using Revit, which do you like more?
Well I haven't used ArchiCAD for years, so I am rusty with it now, the last one I worked on was a few versions back. But to answer your question, I like Revit better. Seems to work smoother, obviously there's some minor things I miss from ArchiCAD but overall, Revit has been a better learning experience and user experience.
Denver, CO
Window & door tag formatting |
Tue, May 30, 2006 at 12:23:29 AM
Free Video - Building Maker Magic ! |
Mon, Dec 7, 2009 at 8:42:31 AM
RENDERING HELP |
Mon, Dec 5, 2011 at 9:29:56 AM
Parallel Boundary Lines? What do these mean? |
Tue, Jun 28, 2011 at 9:36:02 AM
The Story of the Magic Invisible wall - a Revit Bug v2014 |
Fri, Jun 19, 2015 at 2:08:32 PM
Members: | 2105720 | Objects: | 23178 | Forum Posts: | 152305 | Job Listings: | 3 |
